Nissan Z FM radio not letting me access
Ontario, Canada
2023 Nissan Z Proto Spec
My Nissan Z infotainment system is now buggy, I can't access to fm, volume is not working and yes I do have warranty, has anyone else have this problem because this is the first time this happened to me, but the backup camera is working
Nothing like that has happened to me. Though a couple times about 10 seconds after I start my Z, reverse out of the garage, then go back into drive on the road the infotainment system reboots.
Once I had where I could not change the song I was listening to or change volume on bluetooth. Car off then on fixed it for me. Had similar things happen with my Frontier with basically the same system in it. See things like this with a lot of newer cars. More tech = more things that can bug out. Thankfully the few times stuff like that has happened all is well after I turn the vehicle off then on again.
Ontario, Canada
Update: I check it over and it worked perfectly the system just reboot I finally got infotainment system working as normal
Kelly1
Kelly
British Columbia
2023 z performance
I have had the black screen and unresponsive volume but I run a wireless phone adapter ,so Im putting up with the glitches
eventually it sorts itself out,if I’m parked a restart is quicker.,kelly
speedjuno
Speed
Louisiana
Kubota L3301
None
Just a note. On my GMC, radio went haywire. It was the touchscreen. Replaced it, everything went back to normal
I think GM in general has had issues like this with a lot of their cars since they started using touch-screens the 7th gen Corvette (2014-2019) was known to have issues like this as well.
GanZer
Sarasota
Nissan 400z Performance
Business Transformation Consultant
My 2023 Performance Z just this morning had an issue with the AM FM radio... It worked fine on FM, I parked, went into a store, came out and the AM was greyed out, and the FM was not working. Satellite & Airplay worked fine. Maybe its an antenna thing? Was in multiple areas and did the on/off thing to no avail.
