Just throwing it out there that it is an incredible risk to you and any passenger if this is the case. No children passengers jesh.What can be seen is not serious, but the invisible lines under the chassis are very serious. They make my gearbox stop working. So it's not easy to see with the naked eye.
Are you keeping the garbage in a enclosed container? That will help prevent rodentsMy car is parked at the back door. The path at the back door is the place to collect garbage every week and use it to breed mice. Maybe I should deploy four rat cages next to the four tires.
Great point, if you have to buy all new receptacles with tight fitting lids and tidy up the area if you see things tipped etc.Are you keeping the garbage in a enclosed container? That will help prevent rodents
A few yrs ago, our garbage company went on a strike. Neighbors would keep bags of garbage on the ground next to their overflowed cans. Next thing you notice is rats everywhere. Took a long time to rid of them with rat traps.
I wouldnt recommend poison. The rats may die under your house and the smell is bad. The smell goes away after a while, but your senses will never forget
here is a fun one for ya! Try buying some Cat Nip, just drop some around the car. maybe the neighborhood cats will come out to play. Also maybe try bleaching location before or after trash pick up. Anything has gotta be cheaper paying repair bills or movingMy car is parked at the back door. The path at the back door is the place to collect garbage every week and use it to breed mice. Maybe I should deploy four rat cages next to the four tires.
