Infotainment won't detect phone anymore
iBattleMike
Annapolis, MD
RZ34 & FL5
Network Analyst
Solved: Android updates causing issues with all kinds of apps, including Android Auto (pixel 9a)
Recently the infotainment system doesn't seem to fully detect my phone. It will only do Bluetooth connection and that's it. I can't get it to load android auto anymore. I've tried different cables etc, removed device reinstalled, etc. Anyone else run into this issue.
Works fine in my FL5 Type R, so I know it's not the phone or cable
_ds_
North Carolina
2026 Z Performance
I can't speak for Android Auto but I do know that wireless Apple Carplay requires the phone to connect to the cars wifi in order to work. bluetooh does not have enough bandwidth.
Durango 95
West Coast Florida
2026 Nissan Z Performance
Don't have Android or ever had this issue. Have you tried reinstalling your Android Auto App on your phone ? Carefully going through the connection steps again to reconnect it to your Z ? Basically starting from fresh. Also while reconnecting that if you get a dialog box to automatically connect if you answer "No" make sure you don't check the box to "Never ask this question"again". Otherwise you may end up where you are now. Just spitballing.
FatRatZ
2024 Heritage Z, 27 Infiniti QX80, 27 Infiniti QX65
INFINITI Regional Mgr Product Training - NE / Midwest / MidAtlantic
Apple uses WiFi - Android uses Bluetooth.
He is not getting the initial pairing to work - android uses only Bt to initially pair. Once connected - yes, it switches to WiFi for the added speed.
iBattleMike
iBattleMike
Annapolis, MD
RZ34 & FL5
Network Analyst
Yeah I tried all that
iBattleMike
iBattleMike
Annapolis, MD
RZ34 & FL5
Network Analyst
That happened to me. I had to replace the cheap Amazon cable with a better data speed cable.
No issues for 2 yrs
I tried another cable that works fine in my FL5, didn't see to work for the Z. It's strange since this all worked fine a week ago.
Larry
Larry
Lawrenceville, GA
2024 Heritage Z
Retired electrical engineer
I have an uncommon phone, a Sonim. I have it because it's ruggedized and water resistant. It's worked fine with Android auto up until a couple weeks ago. At that time it still worked but I got a pop up message that it would age out and not be supported anymore soon. Well, soon came about 2 days ago. Apparently the Android version is old enough that Android auto is not supporting it anymore. I'll bet you have the same problem. I'm looking into how to install an older version of Android auto and just not update. Anyone know how to do this?
iBattleMike
iBattleMike
Annapolis, MD
RZ34 & FL5
Network Analyst
Have you tried a different phone?
I'll be trying my wife's phone next. Really doesn't make sense as my phone works in another car. I'm guessing a wire got pulled maybe when I took stuff apart to install a short shifter. I know it's plugged in, but I'll have to double check everything here in a couple days
Durango 95
West Coast Florida
As you know its a process of elimination. Try another phone and if it doesn't help you can likely eliminate the phone from "your list of suspects".
iBattleMike
iBattleMike
Annapolis, MD
RZ34 & FL5
Network Analyst
It's the phone after all. iPhone worked fine. Not too long ago, android had an update that hascaused havoc on all kinds of apps. Gotta love lol.
But why it works on my type r and not the Z is beyond me
Durango 95
West Coast Florida
lol. How about that.... You gotta be happy!. I've been in your shoes and it is such a good feeling when you finally get it figured out. (y) Congratulations.
