Backup Camera Stopped Working This Morning (software glitch)
MAPerformance_
Diamond Sponsor
Wisconsin
n/a
So, I hop in my car and pull out of my garage, and I'm sitting in my driveway getting Android Auto connected and messing with my climate controls, when a phone call rings in. I don't recognize the number so I use call screen. Then I get ready to roll and notice that my backup camera isn't working. I go in and out of reverse a few times. No luck. The car knows I'm in reverse because the dashboard shows R, and the correct parking sensors start beeping, but no camera image.
Thinking it's a software glitch, I turn the car off and start it again. Still doesn't work. Made it all the way to work and backed into my parking space, still doesn't work.
So looking around the web a bit it seems like there are somewhat similar complaints, but this one is a bit different. Others complain about about a black screen. I don't have a black screen, the central display just shows what it would if I was in N or a forward gear. It's like the infotainment system isn't clued into the fact that I'm in reverse. The rest of the car seems to know.
Anyway, I'm letting the car stay off for a longer duration to see if it comes back.
Hope you got the problem solved man. If this happens again, You can force your Nissan radio unit to do a hard soft-reboot. Here's how ⬇
1. Turn the car's ignition to ON or leave the engine running.
2. Press and hold down the center Audio Power / Volume knob.
3. Keep holding it for roughly 10 to 15 seconds.
4. The screen will go entirely black. Do not let go yet.
5. Release the button only when you see the Nissan logo reappear on the display.
phil_chronicles
I have done this and it is only a bandaid. Not a complete fix it method
RHE2026
2026 Heritage Edition
Do you know if other Z owners have ever had this similar problem? Sounds like a possible relay switch issue when you go into reverse maybe it’s right under the shifter. What does Nissan say about it?
TurbodToilet
Ben
2025 Nissan Z Performance
my 2025 auto has the same issue and it doesn’t seem like it’s going away. It’s genuinely driving me insane
RHE2026
Is your 2025 still under warranty? If it is I’m pretty sure the dealer will be able to isolate the problem.
TurbodToilet
Ben
It is under warranty but I am adamant about going to the dealer. It’s hard to find the time and I really am not too keen on having an 18 year old ripping apart the interior of my car to replace the head unit. (Joking but half serious)
RHE2026
I don’t blame you on that I am very particular on who works on my car as well. I would ask who there lead tech is. Request him to work on it plus that is who would probably tackling the job anyway. My back display going out would definitely make me nuts.
TurbodToilet
Ben
Yea I’ll just have to bite the bullet and trust the Nissan Techs. Hopefully I don’t pick up a car with a creaky dash and missing trim connectors haha.
I really do wonder what the root cause of the problem is though. Wonder if Nissan will ever put out a statement for it. Wonder if it’s a connector or some kind of logic board within the center console unit that’s causing the issue
RHE2026
I’m taking an educated guess that it’s not your entire info screen having the issue because your display works normally and it only occurs when you shift into reverse. I think it’s something with a hand shake from a switch not working telling the nav system that you’re in reverse. Or I’m thinking if it is intermittent it’s possible that there’s a loose connector trunk or console area. I’m sure they will know exactly where to check first.
