Midz10
Saudi Arabia
Hi Everyone,
Great work there
EZ Ryder9
Couple of questions:
1. After removing the Air to Coolant coolers, did you just plug the lines? because i see that the coolant cooler is still present under the new air to air cooler.
2. Does the cooler box feed something else and is there a need to keep it?
3. What is your recommendation for methanol injection? Since you work with Z1 so closely, are they planning on introducing a methanol injection turnkey system for this model.
Regards,
Sabbi
That is the oil cooler. You remove the water to air exchanger and intercoolers and all the lines.
If you go down in this page you will find the install instructions PDF.
dport
TN
2024 Z - 2015 Q
na
Did this need any retuning to account for the BOVs?
