Fast Intentions 2023+ Nissan Z TDX 2.5" Cat Back Exhaust System
Heavy Dupree
Tampa, Fl
https://www.fastintentions.com/product/nissan-z-tdx-exhaust/
Fast Intentions is proud to present our 2023+ Nissan Z TDX 2.5" Cat Back Exhaust System. This Cat Back exhaust system is the premier upgrade for all Z owners looking to maximize the performance from their VR30DDTT engine. Our cat back exhaust system will enhance the sound that Nissan created from the factory by making it deeper, smoother, and louder. Built as a direct OEM replacement, our exhaust system is easy to install with simple hand tools; no cutting or welding required. Our X Pipe is designed to increase low end torque and maximize power throughout the entire RPM band. The exhaust note is unobtrusive at idle and cruising speeds; but comes to life at wide open throttle. With the addition of our cat back exhaust system, you will improve the aesthetics of your vehicle with its sporty and aggressive appearance.
PRODUCT INFO
  • Direct OEM replacement: no cutting or welding required.
  • 2.5" T-304 mandrel bent stainless steel tubing.
  • Standard 6" x 10" round polished stainless steel perforated core sport mufflers.
  • 4.5" dual wall, polished stainless steel exhaust tips.
  • Optional 4.5″ dual wall, Prismatic (Tri Color) stainless steel exhaust tips. Prismatic Tip Disclaimer
  • 3/8" thick mild steel flanges. All flanges are bright nickel plated to eliminate potential corrosion.
  • All flange connection points are precision Tig welded around the outside. The inside is sanded down and port-n-polished for a smooth exhaust flow. This process reduces exhaust turbulence at the flange connection points.
  • Slip fit connection points with AccuSeal clamps for easy installation and adjustability.
  • Non resonated, or 14" stainless steel perforated core resonators within the X Pipe: Resonators reduce interior noise without hindering performance.
  • Lowest point of the exhaust is the mufflers which sits no lower than the OEM exhaust system.
  • Limited 3-year warranty on all welds, craftsmanship, mufflers and tips.
  • Application Specific: 2023+ Nissan Z (All Sub-models)
  • Compatible on Left- and Right-Hand Drive vehicles.
  • Gaskets, hardware and installation instructions are included.
  • Hand built in the USA.
BENEFITS
  • Refining the factory exhaust note by increasing depth and volume.
  • Reduction in EGT's (Exhaust Gas Temperature) by freeing up back pressure.
ADDITIONAL INFO
  • This product is hand built (in house) to order with a standard lead time of 4 - 6 weeks. Once your order is placed, you will receive an invoice with your estimated shipping date. Note: The lead time may fluctuate less than 4 or greater than 6 weeks based on order volume.
  • California customers are subject to sales tax.
  • Customers outside the continental U.S. are subject to additional shipping charges.
  • Our Prismatic finish is a custom coating process. Color combinations may vary.
  • Image(s) shown may not reflect actual product.
SavedByFaith_
Stephen
2024 Z Nismo
Nice!!!
Any audio clips?
StrikeS30
Paisley, Ontario, Canada
78 280Z, 76 280Z, 88 300zx
Nice!!!
Any audio clips?
There's a couple up on their Instagram. Most of the comments are like omg it's too quiet wtf haha. But, with headphones on it sounds really good. At least for me anyway. It's kind of everything I'm looking for. A nice idle, little growl on throttle. Definitely louder than stock, but not obnoxious. It's also installed with stock downpipes for the clips.
SavedByFaith_
Stephen
2024 Z Nismo
Thanks for the info!
I dont have instagram, but will try to find a clip :)
I find the stock downpipe to be a big limiter on the sound.
From all the videos i scrounged up and watched on YouTube, the Downpipe upgrade to either AMS or MAP (the only two i've seen/heard in videos) are essential to a great sound!
Heavy Dupree
Heavy Dupree
Tampa, Fl
Go2ZZZ
Murdock
Out of all the exhausts I’ve heard for the Z I was waiting for this one. So, far MAPerformance is leading for me but need to hear more from FI
Two I'm interested to hear, both great quality. This and Ark Performance. The Ark is proven on the VQs, love it.
Heavy Dupree
Heavy Dupree
Tampa, Fl
OK, so far we've seen/heard exhaust samples from:
Z1 Motorsports​
MAPerformance​
aFe Takeda​
Borla (which was probably a Q60 Frakenstein-job from a vendor in Puerto Rico)​
Magnaflow​
Fast Intentions​
Nismo (Race/Track and Sport-AT variants, still waiting on sound clips of their titanium cat back)​
Greddy​
Major players still in the que include:
Stillen​
Motordyne​
HKS​
ARK​
aam​
Tomei​
MBRP​
Invidia​
SoHo​
Akrapovic​
GTHaus​
fi-exhaust​
Agency Power​
Feel free to contribute if I left someone out...
Go2ZZZ
Murdock
Z1 Motorsports​
MAPerformance​
aFe Takeda​
Magnaflow​
Fast Intentions​
Greddy​
Stillen​
Motordyne​
HKS​
ARK​
aam​
Tomei​
MBRP​
Invidia​
SoHo​
Akrapovic​
Agency Power​
The magna flow doesn’t sound too bad either. Z1 is nice
for me so far:
1) MAP
2) Z1
3) Magna
maybe someone can have a link for all your list with sound bites
SavedByFaith_
Stephen
2024 Z Nismo
I don't use any social media platforms, but you can view any public account on Instagram without login with this:
https://inflact.com/profiles/instagram-viewer/
FI has posted a YT short of this exhaust, and it doesn't reveal much.
Thank you for the link!
Checked out some of the clips.
I think it's just the quality and the environment.. but didn't sound as great to me
I'm still leaning on the one from MAP as my fav
2.5"? That's unfortunate. I hope they make a 3". FI has been the company I've been waiting on a release from the most.
71zman
John
Indiana
Z1 Motorsports​
MAPerformance​
aFe Takeda​
Magnaflow​
Fast Intentions​
Greddy​
Stillen​
Motordyne​
HKS​
ARK​
aam​
Tomei​
MBRP​
Invidia​
SoHo​
Akrapovic​
Agency Power​
I talked to a Tech rep from Borla about a month ago and they have a Z exhaust in motion. The one that was previously released was not their build. Only parts they offer.
Heavy Dupree
Heavy Dupree
Tampa, Fl
Heavy Dupree
Heavy Dupree
Tampa, Fl
Watch...they'll be selling a 3 inch version for heavily modified vehicles.
