Z1 S-Pro Coilover damping knob
tsungfuyao
Tsung-Fu
CA
Hi all, I have Z1 S-Pro Coilover installed on my 2023 Z, it's really nice!! I feel it's much much better supportive than stock! But I couldn't find out where to access the damping adjuster in the rear, does anyone know where to reach and show me? :p
Btw, what is your setup for front and rear?
D2M
Nismo Z, Veloster N, Ram 2500
No easy access. You would have to remove the trunk trim and adjust then replace it. Or drill a permanent hole tin the trim for the knob to poke through. Another option is to jack the car up, remove the 2 shock bolts and let the suspension droop down enough to see the adjuster, make the adjustment and reinstall. Most coilovers are like this for the Z platform.
tsungfuyao
Tsung-Fu
CA
Then may I ask how to remove the trunk trim? Which piece??
D2M
The knobs will be located under the shock tower humps in the back. These are large trim pieces, look like a pita to remove.
tsungfuyao
Tsung-Fu
CA
Finally I got time to check this out. I tried to remove the plastic piece and exposure the shock tower top. It doesn't look like a knob that I can manually turn :crackup::crackup::crackup: I feel that the knob actually is under the tower, which I'll need to jack the car up and remove the tire lol
