Window roll not fast enough
Car doors with no window frame like our Z's have this mechanism that makes the window roll down a little bit once the door is opened. The whole point is for the glass not to get bent with each opening.
My Audi TT had the same system. But my Z doesn't do it fast enough for me to open the door at normal speed. I have to wait a little bit with the handle pulled, wait for the glass to roll down, and then open the door.
Has anyone else noticed this? Could this be adjusted?
Thanks.
Mud
Brisbane
yeah I noticed this on mine at the dealer while picking it up
I hadn't noticed on any of the demo's i'd driven before.
I just deal with it
up4speed
Long Island, NY
I noticed it too. I click the handle, and pause ,lol
I hate frameless windows that dip, and it just so happens that my 3 favorite cars that I own, have the same garbage! I can't stand it
I just deal with it
That is interesting... I wonder if there is a setting somewhere that can change this...
up4speed
Long Island, NY
I doubt it, it's just physics. The switch is in the handle, so you have to pull the handle to a certain point to activate the switch. So if you pull at a steady rate, you are pulling the door open in one motion, which doesn't leave much time at all for the window to dip. That's why I learned to sort of twist the door handle open, instead of pulling straight out which would open the door quickly. It's more of a twist until the window gets activated, then pause for about 1/2 second, then continue opening.
I'm sure it won't hurt it to pull like a maniac (I'm sure it's designed for it), but it just doesn't sit well for mee, I'm very anal with my cars.
  • Like
Reactions: Mud
It bothered me at first but I guess I am used to it now. Had other cars that had frameless windows that did not do this and they eventually would start leaking when I washed them / got rained on. So I would rather have this than having to keep up with the weatherstripping.
southboundbear
Lawrence
U.P.
2024 Z Sport/Grey
Retired/Engineer
Has not bothered me - yet.
  • Like
Reactions: Mud
Sold the Z
I don't think the switch is in the handle. I think the switch that controls this is the regular door open/close sensor mounted to the body. You can confirm this by pressing this switch while the door is open. The window will roll up.
This means that the door actually has to open a bit before the window rolls down, which could certainly make it seem too slow.
up4speed
Long Island, NY
Oh interesting, ggod point!
I didn't think about that, but now that you say it, I do remember that the door does move a little before it opens. On my other car, it is obvious that the window dips before the door even moves, or even before the lock unlatches, but I still have to pause a little, so it opens nicer.
I'm like you when it comes to my cars... so that's what I do. However, anyone else who may drive it (wife, son) or may get in, would not be as careful as I am with it.
" Had other cars that had frameless windows that did not do this and they eventually would start leaking when I washed them / got rained on. So I would rather have this than having to keep up with the weatherstripping."
Yep! exactly how I feel...
