Disclaimer: how I jack up my car is in no way you should do it. This is a suggestion, not a requirement and I know the risk by doing this. I am not responsible for any damages you may cause to your car by following this method
I use a Dakota Low Pro jack from Harborfreight. Any low pro jack should work. I use 2x4 under the front tires and it gets the front end high enough to jack from the front cross member. This way, I can put jack stands on the pinch welds
For the rear, I jack from the rear diff. I use the jack pads to protect the rear diff from accidental damages that may cause from jacking from the diff. I can put the jack stands on the pinch welds. Do this at your own risk
I use these rubber pads for both the floor jack and jack stands.
I use a super low profile jack with super low profile ramps.If your car isn't lowered, just a pair of ramps for the front will work., if it is, you'll need a pair for the rear as well.
and a mirror against the wall so you can guide yourself up the ramps
