Can you push start the RZ34?
dogunbound
Shane
Houston, TX
Software Engineer
I kind of got curious and saw this in the owner's manual:
Do not attempt to start the engine by
pushing.
CAUTION
. Automatic transmission models
cannot be push-started or tow-
started. Attempting to do so may
cause transmission damage.
. Three way catalyst equipped
models should not be started by
pushing since the three way cat-
alyst may be damaged.
. Never try to start the vehicle by
towing it; when the engine starts,
the forward surge could cause
the vehicle to collide with the
tow vehicle.
What I am getting from this is that It doesn't necessarily say that you cannot push start this car, but you simply shouldn't.
Exclude points 1 and 3 for obvious reasons. Point 2 seems interesting. I'm assuming all trims have been equipped with a 3 way catalyst. I don't know why a catalytic converter would be damaged due to roll starts, but Nissan engineers are not stupid and put this warning in the manual for a reason.
Anyways, I wouldn't want to make a habit of having to push start, but how would you even do it (if you could)?
These are the steps I presume are to be taken (but I don't really know since the manual doesn't say how to):
1. Put the car in ON mode
2. Start moving the car or roll it down a hill
3. Depress clutch and put it in 2nd or 3rd gear
4. Pop the clutch once sufficient speed is met with your chosen gear
I've never done it, but maybe one of ya'll have out of curiosity.
Sounds like this is just for automatic trans cars - which makes sense. I personally would never try to start any car with an auto-trans this way. I've done it with a manual trans before, just to see how it works with an old Chevy quite a few years ago.
However if the reason you are doing it is because of a dead battery (and you happen to be on a hill where you could get speed and dump the clutch) I not sure you would be able to put it in "on" like older cars where you had a key to turn for which position the car would be in (Off, ACC, ON)
If I had a manual trans and found myself in a situation where I needed to do this I do not see why it would not work.
Sold the Z
Maybe the ignition system isn't active in ON mode unless software started the engine. I don't know if this is true, but with the increasing level of computerization, it seems possible.
dogunbound
dogunbound
Shane
Houston, TX
Software Engineer
Usually the battery isn't all the way dead in my experience (03 camry, 11 altima, etc...). It usually has enough to run the fuel pump (I can hear it), but not enough to crank the motor with the starter.
I don't think even with computerization it would matter since the computers itself probably use very little electricity. As long as it gets some kind of voltage, it probably could put it in ON mode.
Maybe if the battery is all the way dead (left it in non-shipping mode for months), then you might be SOL.
mikecarpage
Bay Area, CA
Sales
does the automatic require pressing the Brake pedal to start like other keyless/push to start cars?
Mud
Brisbane
I'd swap 2 and 3 ;)
