Budget Bose upgrade underway - Pioneer TS components / Kicker Key 200.4 / Kicker Hideaway HS10 sub / OWC Harness Interface
staying_tuned
Kentucky
23’ Z Performance Manual
Hey folks, I have been planning a budget oriented upgrade for a few weeks but needed to wrap up a few things. I performed a near identical upgrade on my F150 and couldn't be happier with the results. I was able to stay under $1,000 on that, my harness is about $150 more on the Z though so I believe I'll be just under $1,200.
Gear includes:
Door Speakers: 6x9 Pioneer TS-A693FH - Very solid 6x9 in a great load range for the Kicker Key amp.
Dash Midrange & Tweeters: 2.75" Pioneer TS-A709 - Robust sound from that location with these 2.75" 2-ways. Also a great match for the Kicker Key amp.
Kicker Key 200.4 DSP Amp - Drives components, DSP Auto-tune, very compact size. I love this little beast.
Kicker HS10 Powered Sub - This little powered 10" offers very clean yet impactful base. Enough to where I've got it down to 1/4" in my F150. It can hit pretty hard but most importatnly, doesn't get sloppy.
Knu Koncepts - 4G OFC Amp Install Kit w/ 4G > 8G distribution block. 8G out to kicker HS10 sub and Kicker Key Amp.
Knu Koncepts - Kno Knoise XT Deadener (120ml for the floor. I've got 50/80 here at the house)
OWC Harness - Custom created to omit rears speakers which coincidentally saved me $60.
The Kicker Key with DSP tuning is incredible and so tiny it fit behind the head unit in my truck. Like the F150 I'm going to remove the rear panel speakers entirely and focus on the front door & dash components while incorporating a powered sub. I worked with Chris at OWC Upgrades on a harness which is a variation of his "Replace Factory Amp" configuration which will omit the rear panel speakers entirely.
The end result will be:
- Zero splicing, OWC's harness plugs into the Bose amp & harness.
- Pre-amp signals via RCA to Kicker Key DSP (drives components).
- Dedicated 2 channel RCA for sub.
- Leverage existing speaker wire runs for components.
After sound deadening my trunk I went ahead and started pulling panels and eventually seats and door panels. A few things I was pretty surprised with:
- It had been posted before that the doors were sealed up nicely from the factory. These doors are indeed amazing. Even what could be considered somewhat of a blocking plate has a gasket from the factory! All holes were either covered via pliable grommet or decal and they didn't rely on that cheap rubber slathered plastic sheeting as a moisture barrier, it's just sealed up nicely from the factory. I'll likely just go with a 50ml deadening skin and closed cell foam on the doors with 90ml & 120ml on the floor.
- The central area where the factory bose amp is located is quite roomy. The bose amp has a mounting housing that takes up 5 times the space of the amp so by the time you remove the fluff, you have a nice area to work with and position additional gear. In the below photo you can see the stock amp lifted and set aside in the upper right area. Also notice the fuel pump deadener squares they have on there. They are loose and just set in place but nice that they thought about it.
- The floor has a surprising amount of rigid mass builder/deadener. I'm going to cover most of this with deadener but all those gray grid-like sheets are OEM deadener. It's the hard stuff that tends to shatter off, learned to leave this $hit alone awhile back. I'll deaden over all of it.
I'm currently waiting on the equipment. I have the deadener so I'm going to take my time and cover it well, then move onto the rest. I'll document as things progress.
Thanks a ton for all of the R&D and postings from various members along the way, it has been a tremendous help!
staying_tuned
staying_tuned
Kentucky
DAMN! I felt like Yoda from my upgrades I made to my Sport's audio. You and @Exquisite_Red make me want to film myself eating crayons, and just put those vids in my thread.
Haha, I must have visited various posts from you, Exquisite and Mac multiple times per day for nearly 1 month straight just getting my ducks in a row. Thank again for posting your findings, I already have a bamboo kabob skewer stuck through that grommet & insulation on that pass battery box so when ready I can run that amp's 4G.
My young boys and I have turned it into somewhat of a fort. With the seats out they just hang in there doodling and racing matchbox cars. They've hopped through my trunk I suspect about 200 times. In and an out like some type of field mice. I ended up putting a tender on it.
They leave entry and exit residue. You'd think they just ate 10 corndogs with all the prints hahaha.
Ckynus
Film
From my own audio install I can tell you just killing those 2 rear rattling speakers is a giant gain. The Z cabin is small enough were I found I didnt need that fill.
staying_tuned
staying_tuned
Kentucky
Opted to switch from the JL C1-690 components to the Pioneer TS-A693FH in 6x9 for the doors and the Pioneer TS-A709 2-3/4" 2-ways in the dash. A bit pricier than the JL components but the TS-A709 seems fantastic and should be warmer than the JLs. I've had nothing but great experiences with Pioneers (mid-grade or better) 6x9s. I'm still omitting the rear panel speakers entirely.
I took a few shots of the Bose factory speakers in case anyone in the future could use them. The order below (top down) would be dash, doors then rear panels.
Nissan AND Bose should feel bad and shamed for putting such $#!+ components in. Those rear speakers look like the crap ones from the sport with "BOSE" stenciled on.
Gear includes:
Want to remove sticky deadener the fun way?
Dry ice!
@staying_tuned How are the Bose 6x9 speakers mounted? Specifically, are there spacers that move them closer to the door grille?
Just wondering, as I'm curious if 2 ohm 6x9s are a more viable solution for us Sport owners than trying to find 6.5" 2 ohm speakers.
staying_tuned
staying_tuned
Kentucky
They have angled spacers but the door panel itself has a 6x9" cutout. The factory spacers provide a bit of space, perhaps 1" on one side and 1.5" or 1.75" on the other, the factory spacers provide a nice angle. It's one concern I have on the metras that are coming, they don't appear to be angled and I don't think I'll be able to reuse the factory ones.
It looks like the only difference between sport and perf doors on the speaker is the adapter plate. Since new rings are required for my 6x9 upgrade anyhow, I bet you could run 6x9 no problem by just removing the 6.5” plastic blocking plate. Here is mine the
staying_tuned
staying_tuned
Kentucky
Made some more progress over the past few days and figured I'd post some pics. Once the paneling and seats are out the car becomes very comfortable to crawl around in and work.
For the floors I've been running base layer of 50mil & 80mil deadener (pretty thin but very easy to work with & roll) coupled with spot applications of 120mil. The 120mil (Knu Koncepts Kno Knoise XT) is absurdly thick, weighing it at 1lb per sq/ft.
Speakers arrive today so I should be able to wrap up the doors.
Driver Floorboard Completed
Passenger Before, After & Cabling. I had no problem running 4G through the existing OEM harness loom which runs all the way down the sides.
Behoooold, the only piece of aluminum rubber butyl based Nissan factory deadener I found on the entire car hah. Nissan focused their deadening efforts more-so here than anywhere else so I wanted to break this area down a bit and cover it pretty decently.
Metal bracketry back together, factory sound deadener pads back in place.
When I did my trunk / well area, I found that single, solitary piece of deadener!
AND IT WAS ONLY HALF STUCK ON!
Incredible work. Keep up the attention to detail.
staying_tuned
staying_tuned
Kentucky
I got the 6x9s and tweeters installed. I lucked out on the 6x9s. Despite Crutchfield sending me metra spacers, I didn't need them. A small plastic nib blocked the new speakers from fitting perfectly so I used my dremel to shave it off and they slotted perfectly.
The tweeters worked well with the red wolf adapters. I needed to bore the mounting holes down a bit to line everything up but they mounted perfectly.
6x9s in factory location
Tweeters Prepped
Tweeters Installed
ikazuchi
DFW
Which adapters do you have for the 6x9 in the picture?
Is that the OEM mounting?
staying_tuned
staying_tuned
Kentucky
The 6x9 speaker wiring adapters were included with the purchase of my speakers at crutchfield, here is a direct link to them if you wanted to purchase them separately: https://www.crutchfield.com/p_120727401/Metra-72-7401-Speaker-Wiring-Harnesses.html
As for the mounting, yes that is OEM. Crutchfield included spacers but the OEM spacers worked very well. I like the OEM ones better because they are angled upward and have a foam gasket.
staying_tuned
staying_tuned
Kentucky
Circled back on the main power to install an inline fuse, got the Kicker Key 200.4 yesterday. I've already got one in my F150 (hidden behind glovebox) and figured I'd post a pic given how incredibly small they are. This is a regular ol' 12oz can. It's amazing they can fit a legit 50x4 amp with such a vast array of options (by far the coolest is DSP tuning with a mic port). You just hook the mic up and allow it to play its test tones and it automatically tunes based on your preferences.
Interior is back together, so nice to have seats back in. No broken or missing clips just yet. The central pieces which wrap the roll-bar are a PITA unless you start with them first when putting the interior back together. I made the mistake of running the sides up and back first. I had to take them back out, lesson learned is pull the center bar stuff last, put it back in first. Only pieces I've left out are the rear trunk padding and surround trim pieces. I want easy access to the stock amp area, just waiting on the adapter from OWC now. I've got a distribution block to get in which will split that 4G into 2 8G legs for the amp and powered sub along with provisioning a few grounds. I've got what I need for that so just pretty much waiting at this point.
