using the right wheels
Bodz
Kendrick
Philippines
Miata, beetle
Manager
hi z bros, is any one here using nissan z performance with bbk nissan break kit was wondering does 18's fit well with the brake caliper and rotor of the performance model thank you
shingo
Shingo
Hawaii
Z1’s “Track Big Brake Kit” with 15” rotors and 6 piston front calipers, 4 piston rear calipers says you need 18” or larger wheels to install (but it also says it will only fit certain 18” wheels) , so I’m guessing if you’re sticking with a BBK close to that you probably shouldn’t have any issues. Z1 has a caliper template you can download and check to see as well.
Here’s the bbk ad where you can get the template: https://www.z1motorsports.com/brake-kits/z1-motorsports/z1-2023-nissan-track-big-brake-kit-front-and-rear-p-47476.html?list_name=CategoryCompleteBBK&oid=47476:0:83666:50&qid=4b8e3431d2fdbba03839bc233df04759
Bodz
Bodz
Kendrick
Philippines
Miata, beetle
Manager
so i could assume with the stock performance brake kit on the stock z i could still fit 18"s
Jah_Happy
Yes, 18s will fit as long as the offset isn't something crazy
Bodz
Bodz
Kendrick
Philippines
Miata, beetle
Manager
even with the 14" rotor and the floating caliper of the nissan z performance thank you for the insight
