Tomei single exit + ISR Y pipe?
KelvinllMelvin
kelvin
Nissan z
My Tomei single exit has been holding up fine. I had to drop the exhaust a couple days ago for a sway bar install, so I was under the car and had a good chance to see how it looked. There's a few deep scrapes where the exhaust hit the ground (speedbump, etc., but there is no evidence of weld failure, metal failure [titanium is a strong metal] and there are no structural changes or deformities to any of the pipes. The exhaust hangars and clamps are also performing admirably with no leaks or sagging.
I cannot speak for Tomei USA being manufactured in China or elsewhere or their quality compared to Tomei JP, but I the one I purchased has proven to be a quality piece. I will also add that there is a low point where the exhaust goes under the rear axle, but it hasn't proven to be an issue at stock ride height. It might be a point of concern if the car was lowered.
The exhaust sound has also improved as the system ages. It's a bit louder (not by much) and the tone is a little deeper. I still feel it's the best exhaust sound for a Nissan if you're chasing that classic JDM tone.
Appreciate the vid quote too. :)
Is the low point at all adjustable? I’m guessing if so the exhaust tip would look uneven but I wouldn’t mind the slight offside of the tip if I could bring the low point a little higher. I’m on lowering springs therefore car sits a bit low.
