Super SQV4 Return Kit Plus Blow of Valves
HKS announces Super SQV4 Return Kit Plus Blow of Valves for the RZ34
price is around $1300 converted from Yen
The "Super SQV4" is a sequential blow-off valve that is compatible with the VR30DDTT engine installed in the Fairlady Z. It is placed on the left and right banks of the engine and quickly releases unnecessary boost pressure from the left and right turbochargers when the throttle is off, reducing the burden on the chargers.
The hose between the turbocharger and the intercooler is changed to a special 4-ply silicone hose included in the kit, and the Super SQV4 is installed. By changing the hose, the hose section is also strengthened at the same time.
The Super SQV4 uses a unique sequential valve structure. The differential pressure control system realizes pressure control over a wide operating range, from low boost to high boost. The main body is made of aluminum die-cast body + silver paint, which gives it an overwhelming presence and durability in the engine bay. The kit uses black-based colors for all parts other than the main body, making the Super SQV4 main body stand out.
