Status
Not open for further replies.
Caleb@PandaMotorworks
Caleb
St. Louis MO
www.pandamotorworks.com
2023 Sport, Rosewood Metallic
Marketing @ Panda Motorworks
Does your state require a front plate? Don't like the bulky OEM mounting position? Luckily for all of us, Mishimoto has a No-Drill solution that works great and is 100% reversible! Check out or Overview and Install video below!
Don't forget to hit subscribe while you're there! So close to 5k ?
LICENSE PLATE RELOCATION KIT, FITS NISSAN Z 2023+
PRODUCT FEATURES
  • Direct fit for 2023+ Nissan Z
  • Installs in under 15 minutes
  • Eliminates the need to drill holes in your front bumper
  • Mounts to OEM front tow hook with no permanent modifications required
  • Includes all necessary hardware for installation including stainless-steel license plate screws
  • Fabricated from high-strength 6061 aluminum
  • Angled to follow contours of the bumper and reduce wind resistance
  • Anodized black shaft and powder-coated black plate bracket for a durable, corrosion-resistant finish
  • Allows full airflow to radiator and FMIC
  • Mishimoto Lifetime Warranty
DESCRIPTION
The all-new 2023+ Nissan Z is a sleek showstopper. What’s not-so-sleek? Its front license plate location. Sitting directly in the center of the grille, the front plate obstructs airflow to the radiator while also creating wind resistance. Luckily, there’s no need to worry about drilling holes in your new bumper because Mishimoto has a solution: the 2023+ Nissan Z Mishimoto license plate relocation kit!
Designed specifically for the 2023+ Nissan Z, our license plate relocation kit is constructed from high-strength, anodized and powder-coated 6061 aluminum. It mounts directly to the OEM tow hook location, allowing for a clean and seamless installation. Angling and relocating the plate to the side not only helps reduce wind resistance, but it also frees up grille space, facilitating critical airflow to your radiator and letting your Z breathe easy. And let’s be honest, it just looks better! The days of ugly holes in your bumper are no more. Our license plate relocation kit includes all necessary hardware for an easy installation, and as with all our products, this kit includes our signature Mishimoto Lifetime Warranty.
PURCHASE INCLUDES
(1) License Plate Mounting Bracket
(1) Front Tow Hook Mounting Shaft
Mounting Hardware
HP Proto
Harry
Mono
2023 Nissan Z Proto Spec
Broadcast Engineer
PRODUCT FEATURES
DESCRIPTION
PURCHASE INCLUDES
Mounting Hardware
Don’t waste your time buying this, it doesn’t fit 2023 Z. I bought it and had to return it.
Caleb
St. Louis MO
Huh? This kit is specifically for the 23 Z
We installed it on the video above, definitely fits haha
HP Proto
Harry
Mono
Broadcast Engineer
Caleb
St. Louis MO
Nope I have a letter from you guys stating it needs more work.
Ah so it's a Proto Spec fitment issue. Good to know
Ours fit perfect on our Sport
loudsx
what are the dimensions of the plate and holes?
curious if will work for non USA plates.
Jah_Happy
What part didnt fit? Was it the threads on the rod? I cant imagine the Proto being different at all but I dont know.
HP Proto
Harry
Mono
Broadcast Engineer
Yes, it was bigger then the toe hook.
HP Proto
Harry
Mono
Broadcast Engineer
It fit on my z ok. What didn't fit?
this didn’t fit in toe hook, threads diameter was bigger and didn’t go into toe hook.
HP Proto
Harry
Mono
Broadcast Engineer
I had the z1 tow strap on for about a week and replaced it with the mishimoto kit, It fit on my Proto
Maybe they fixed it by now, I tried about 2 months ago.
Status
