EarlsFat
- Thread starter
- #1
Was just curious if anyone else's car shifting is a little... off... when going up hills that had a significant rate of incline? I just drove from Lynchburg VA to Oxford PA yesterday, and while going up the bigger hills that thing was VERY spongy (? for lack of a better term) on the downshift and acceleration. So for instance - if overgeared for the speed / rpm's, and you press the throttle, it would downshift and increase rpms, but you'd have to press the throttle MORE to actually make it go faster. Just seemed like it wanted WAY to much pedal to get it to slightly go faster.
I'm not really sure it was turbo lag, almost seemed like the transmission/rear end was slipping and the motor was overspinning to get the job done. This thing isn't a CVT transmission with some sort of shift mimic programmed into it, right??? Because it kinda almost felt like the lag in a snowmobile transmission.
When on flat pavement or little hills this (i95, i70 or 695 for example) didn't happen, down shift and accelerated as you would expect with a minor press of the throttle. It only seemed to be on the larger hills, going up mountains / inclines that were 1/2 mile + (on 29 and i64 crossing the mountains near Lovingston, and Staunton for example).
Side note... did not see another Z on the entire trip, lol.
