Heavy Dupree
- Thread starter
- #1
They kind of snuck this one in on us...
https://www.amsperformance.com/product/ams-performance-nissan-z-port-injection-lower-manifold/
The AMS Performance Nissan Z Port Injection Lower Manifold is the ultimate fueling solution for high horsepower applications. Working in conjunction with your existing direct injection system, adding port injection allows for a substantial increase in fuel capability than direct injection alone. Simply add in your preferred size injectors, plumb your fuel lines, and set up a controller to calibrate the system accordingly. Constructed of CNC machined 6061 T6 billet aluminum, the AMS Performance Nissan Z Port Injection Lower Manifold is the foundation for your port injection build.
- CNC MACHINED 6061 T6 BILLET ALUMINUM MANIFOLD RUNNERS AND FUEL RAILS
- INJECTOR NOZZLE ANGLE DESIGNED TO MAXIMIZE FUEL DELIVERY TO COMBUSTION CHAMBER
- DESIGNED FOR BOSCH EV14 TYPE INJECTORS
- REUSES OEM O-RING GASKETS AT LOWER MANIFOLD TO HEAD CASES
- HELPS PREVENT CARBON BUILD UP ON INTAKE VALVES
- -6AN PORTS ON RAIL ENDS FOR EASY FUEL LINE CREATION
- FULLY ETHANOL COMPATIBLE (E100, E85, E50, E30, ETC.)
