jbarth09
Albuquerque
Possible Acquisition Soon
Hello, All,
Well, Some of you might have seen my post here about someone backing into my car when I only had ~800 miles on the car. Bad luck I guess, but, I decided to go a different way about repairing. Here is a pic of the damage from the inside of the bumper.
I decided to replace the bumper in its enirety with the 2025 only accessory bumper. I guess for a time, in the 2025 model year, this bumper could be optioned with the car and it would come installed from the factory. This can be purchased through APEX'i USA here
Before we got started.
Unboxing.
All the harness extensions and necessary parts. We did re-use a lot from the original bumper.
The entire bumper harness needs to be removed from the original bumper. 2 sensors needed to be relocated. They provide a long and a short cable to relocate them, however, I don't think it matters was side you use the long or the short length extensions cables. At least from my eye, they both had enough slace and could have been used on either side. Additionally, you have to pull the metal brackets out of the original bumper.
Sensors relocated.
In this picture, I forgot to include the 1 black sensor bracket. when I started the car, I didn't see anything different or have any codes, but it is something I want to correct in the future. I still have the bracket, but the bumper was already back on and buttoned up before I noticed. I'm sure I can reach it if I take the radiator cover off.
Driver side sensors installed. Of Note, they give you two new stick on brackets for the outboard parking sensors. There is an outline on the bumper on where they go. Easiest way is to put the sensor in the backets and use the rubber / silicon cover as a guide to get them straight. Also, important to remember is that two of the sensors are painted in body color and two of them are black.
Of Note, they give you two new stick on brackets for the outboard parking sensors. There is an outline on the bumper on where they go. Easiest way is to put the sensor in the backets and use the rubber / silicon cover as a guide to get them straight. Also, important to remember is that two of the sensors are painted in body color and two of them are black. They also include new hold down tape to attach the harness back to the bumper.
If anyone knows what these sensors do, i'd love to know. I'm guessing some kind of safety / airbag sensors.
Biggest gripe, is that they pre-drilled for a front license plate. I'm guessing this has something to do with laws in Japan as I did not have a choice here. It's how it shipped from the motherland.
However, once it's removed, I used two of the covers that were included to cover up the holes.
you'd never know they were there because this section of the bumper is inside a crevice / grill section.
Here is the bumper installed. Not quite on the ground. It started raining so we decided to start cleaning up and getting the Z Parked.
Enjoy!
Jonathan
EDIT:
jbarth09
Albuquerque
Is the Fairlady Z emblem removable?
It is removable. However, that section of the bumper has an embossed place for it to go. Without it though it looks like this.
you can see the embossed area in the red.
SleepyD7
David
Gainesville Florida
2024 Manual Nissan Z Performance, 2013 Nissan Xterra, 2020 Lexus IS3050
Audio Video Integration Sales
I likey buut $2.8k 😶
